Forums >> Revit Building >> Technical Support >> How do I cut cabinet to host recessed light? Using Revit 2009
Thu, Apr 17, 2008 at 8:16:27 AM | How do I cut cabinet to host recessed light? Using Revit 2009
qthdad
5 Stars: 2 Votes
I modified a recessed light to stick under a standard cabinet for use as an under-cabinet puck light but it does not cut the underside of the cabinet like it does a ceiling. I've also tried using the unmodified light that is delivered with Revit, it too does not cut the cabinet. The result is that light does not come out. Is there a way to cut the cabinet without modifying the cabinet family?
Thu, Apr 17, 2008 at 8:24:06 AM | How do I cut cabinet to host recessed light? Using Revit 2009
 Do you want the light to cut the cabinet so that it will work correctly in a rendering or is this a detail issue?
Thu, Apr 17, 2008 at 8:29:04 AM | How do I cut cabinet to host recessed light? Using Revit 2009
qthdad
5 Stars: 2 Votes
Just for rendering. Thanks.
Thu, Apr 17, 2008 at 8:35:23 AM | How do I cut cabinet to host recessed light? Using Revit 2009
In that case, you have to edit the family.  If you have just one unique instance, that might just be as simple as adding a void in the family.
Thu, Apr 17, 2008 at 8:46:04 AM | How do I cut cabinet to host recessed light? Using Revit 2009
qthdad
5 Stars: 2 Votes
Yeah, I was afraid of that. I wanted to be able to use multiple instances and also be able to adjust the light position to achieve the best rendering.
If it were for a detail issue, what did you have in mind as a workaround?
Thu, Apr 17, 2008 at 9:48:44 AM | How do I cut cabinet to host recessed light? Using Revit 2009
How about taking the cabinet top out of the cabinet and placing a parametric plane arount your light.  Now when you place that light, you can grap the grips and adjust tem for each placement.
Thu, Apr 17, 2008 at 10:00:03 AM | How do I cut cabinet to host recessed light? Using Revit 2009
qthdad
5 Stars: 2 Votes
Good thought. How about if I made the hosting surface in the cabinet family as a ceiling? Another option, is to leave out the surface as you say, but then create a false ceiling in the model to host the lights. Thanks for the help. I just wish I could model it the way I would actually build it rather than having to "cheat." Revit can cut holes in walls and roofs, why can't we cut holes in other surfaces? Thanks for the help. This will work (I think) for now.
Light Fixture - Recessed
Fri, Nov 13, 2009 at 9:14:57 AM
Recessed cans = no light
Fri, Mar 6, 2009 at 7:41:57 AM
Recessed Cans... Revisited
Tue, Aug 4, 2009 at 2:39:08 PM
Fire Extinguisher Cabinet
Wed, Sep 20, 2006 at 12:07:50 PM
Recessed linear light
Tue, Feb 3, 2009 at 1:48:45 PM
Page generation time: 7.1651
