Forums >> Revit Building >> Technical Support >> Shared parameters
Wed, Mar 23, 2005 at 12:44:52 PM | Shared parameters
jporos
I'm trying to create demo tags that would work with a schedule. When I try to create the annotation, the Family editor will not let me choose Shared Parameters. What am I doing wrong?
Wed, Mar 23, 2005 at 9:22:07 PM | RE: Shared parameters
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What template are you using... Depending on what elements you are demolishing, i'd use the multi-category tag so i can tag doors, walls, windows that are demolished all with the same tag. Then select shared parameters, either browse or create a new shared parameter file. Then create a new group and start adding your shared parameters.... HTH.
Tue, Mar 29, 2005 at 11:27:08 PM | RE: Shared parameters
jporos
Thanks Mr. Spot. Will try that.
Shared Parameters
Thu, Feb 9, 2006 at 1:41:58 PM
Shared or Project Parameters?
Tue, Jan 19, 2010 at 7:01:11 PM
Project Shared Parameters or Shared Parameters in Families
Fri, Feb 21, 2014 at 10:22:42 AM
Creating Shared Parameters
Tue, Nov 25, 2008 at 4:45:08 AM
Shared Parameters File is not a valid...
Wed, Feb 12, 2014 at 9:31:26 AM
Page generation time: 5.0746
