Forums >> Revit Building >> Technical Support >> Material Hatch Visibility
Tue, Apr 15, 2008 at 1:53:41 PM | Material Hatch Visibility
daphnism
Ok. Here is another issue that I encountered.I have this typical spandrel window type which I assigned as a family. I added the insulation behind the glass in ‘edit family’ mode. But it doesn’t show in my overall plan, neither does hatch of insulation. Checking Visibility – done View extend option – doneLoaded into project correctly - done Everything shows in the family editor not the work plan.  Any other possible solutions? Thanks so much in advance.
Tue, Apr 15, 2008 at 1:59:12 PM | Material Hatch Visibility
Not sure what you mean when you say you added insulation to the family.  If this is a 3d element that you have assigned the material insulation to it, is this material defined in the project?
Tue, Apr 15, 2008 at 2:08:50 PM | Material Hatch Visibility
daphnism
yes, it is 3d element , and it is assigned into the project.
hatch pattern in material anomolies
Fri, Aug 26, 2016 at 9:35:26 AM
Help of Hatch Tile in a Ceramic Material
Fri, Aug 31, 2018 at 10:15:19 AM
Can't Change Hatch Material On Wall
Mon, Oct 14, 2019 at 11:01:30 PM
Hatch rotation in door family
Wed, Jan 21, 2015 at 11:55:18 AM
HATCH 22- REVIT MODEL HATCH
Fri, May 8, 2015 at 3:01:04 AM
Page generation time: 1.5391
