24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Having Dimension text in string, not above dimension string
Hello there, I did some searching and cannot find out how to do this by default. I can grab the text and move it so it's sitting in the dimension string, but I cannot have it set by default. In the settings the closest I can get is 0" which is sitting right on top of the line. Not in it and I cannot set that gap length to a negative number. Anyone know how I can do this? Thanks.
Denver, CO
Revit Architecture |
51 Posts No Rating |
Sorry to revive an old thread, but I'm having a similar problem. I do NOT want to use the manual overrides for dimension strings, but would like for the dimension text to appear BELOW the dimension line. Revit will not let me use a negative value for the text offset. Ultimately, what I need is a dim string with imperial values above the line, and metric below, but I do not believe that is possible. Someone prove me wrong...
Forgot to mention, using Revit 2009.
http://revitcity.com/forums.php?action=viewthread&thread_id=3324 Now I know you will come back and want to argue but this is your best answer.
Pretty much what I have done so far, but I gave one a text offset larger than the other. This leaves me with a single dimension line with TWO lines of text ABOVE the line. Not too bad, but ONE line above and ONE line below would be perfect.
Dimension strings not adding up to the total length dimension string (2017) |
Fri, Mar 23, 2018 at 1:33:58 AM
Adding a dimension to a dimension string... |
Wed, Jul 10, 2013 at 3:42:09 PM
Removing/editing single dimension in dimension string |
Wed, Aug 26, 2009 at 7:12:02 AM
dimension string problem |
Thu, Oct 18, 2007 at 1:21:31 AM
Dimension String |
Wed, Nov 22, 2006 at 3:05:15 PM
