Forums >> Revit Structure >> Technical Support >> Roof fascia!
Tue, Apr 15, 2008 at 5:32:53 AM | Roof fascia!
Look at the  image,how to get the two roof fascia joined well..Thank you...
Tue, Apr 15, 2008 at 8:35:46 AM | Roof fascia!
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
There is kind of a bug with fascias. If you don't draw the whole thing at one time you can get messed up corners. Try creating the fascia as one piece by picking all of the edges that need fascia applied.
Tue, Apr 15, 2008 at 9:23:21 AM | Roof fascia!
First,thank you for your help.
I had maken the roof fascia by each piece of the edges,but get the same result.
Did you try it?
Or any other ways to deal with the problem?
Tue, Apr 15, 2008 at 9:47:00 AM | Roof fascia!
Delete the one we see as white in your jpeg.  Then click on the other and choose add or remove walls from the options bar.  Now select the other wall and the corner should be correct.
Tue, Apr 15, 2008 at 10:56:31 AM | Roof fascia!
Thanks for your help.
Look at the images 01,02,and 03 ,do you mean this?
But it seems doesn't work...
Tue, Apr 15, 2008 at 11:58:32 AM | Roof fascia!
Don't know what your doing but it works fine here.... just tried it again.  Works for both fascias and cornices.
Wed, Apr 16, 2008 at 1:44:55 AM | Roof fascia!
phildixon
1 Stars: 1 Votes
Select one side of the fascia and use the grip point to drag it back to the correct location.
Wed, Apr 16, 2008 at 1:47:29 AM | Roof fascia!
phildixon
1 Stars: 1 Votes
Wed, Apr 16, 2008 at 3:36:01 AM | Roof fascia!
270973691
Thanks for all of your help.
Maybe it's mistake,i didn't show the question clearly..
Please see the image i showed,the roof here is  a slope.
How can get the two roof fascia joined together?
Wed, Apr 16, 2008 at 5:28:22 AM | Roof fascia!
KingRevit
4 Stars: 12 Votes
its how u made your profile see images below.
image on the left is the wrong way to make that profile image on left is the correct way to make that profile.
Edited on: Wed, Apr 16, 2008 at 5:31:19 AM
Thu, Apr 17, 2008 at 3:05:50 AM | Roof fascia!
270973691
The way i made the profile is correct.But when i make the roof fascia,the corner here is always can't joined well.
Do you make the roof fascia and can it joined well?
Thu, Apr 17, 2008 at 3:42:16 AM | Roof fascia!
KingRevit
4 Stars: 12 Votes
i re made your example and it works fine, re make your profile as i have shown and it should work if you like you can post yo0ur file.
Thu, Apr 17, 2008 at 4:09:31 AM | Roof fascia!
#13
270973691
I have re-make the profile as you shown,and make the roof fascia as i attached (Roof fascia-01),the corner is joined well.But this is not what i want..
The roof fascia here is outside the roof,next to the roof,what i want is the image (Roof fascia-02),the roof fascia under
the roof.
Mon, Apr 28, 2008 at 7:22:31 AM | Roof fascia!
#14
KingRevit
4 Stars: 12 Votes
when placing the fascia offset it.
How to miter a fascia on a sloped roof?
Fri, Aug 24, 2012 at 7:48:23 AM
Roof fascia curves in plan and elevation
Sun, Dec 13, 2009 at 1:40:44 PM
Roof Fascia On Negative Sloped Roof
Wed, May 15, 2013 at 9:47:35 AM
roof fascia
Fri, Jul 27, 2007 at 1:29:36 PM
Adding fascia to curved roof.
Mon, Dec 13, 2010 at 9:21:59 AM
Page generation time: 0.4321
