Forums >> Revit Building >> Technical Support >> How to create a coved/ radiused corner at Floor-to-Wall Wall-to-Ceiling
Mon, Apr 14, 2008 at 5:44:21 PM | How to create a coved/ radiused corner at Floor-to-Wall Wall-to-Ceiling
just
Any suggestions how to create a coved floor-to-wall transition and wall-to-ceiling transition?  For a clean room type application.  Can this be created as a wall type or does it a need to create a profile for the ceiling and a seperate one for the ceiling transition.
 Using Revit Building 2008
Tue, Apr 15, 2008 at 8:40:05 AM | How to create a coved/ radiused corner at Floor-to-Wall Wall-to-Ceiling
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I would do these as hosted sweeps. I am pretty sure you will have to create two different profiles because one will be inverted. You might try mirroring the first one but I don't think that will work.
Corner guards to snap to corner of wall
Tue, May 13, 2014 at 12:18:44 PM
Curved Sloping Curtain Walls....
Thu, Nov 27, 2008 at 12:37:24 PM
Revit 2015 join wall to underside of floor and ceiling issue
Wed, Mar 2, 2016 at 2:59:03 PM
radiused corners at door and window openings?
Mon, Oct 25, 2010 at 6:08:57 PM
Wall and Ceiling Issues
Tue, Jan 20, 2009 at 7:50:47 PM
Page generation time: 3.4465
