18 Users Online (16 Members):
Forums >> Community >> Newbies >> Callout
When I identify a callout detail, it constructs the area with a rectangle with rounded corners. How do I change the rectangle with rounded corners to appear as a circle that will be used to identify the detail area?
go to menu->settings->view tags->callouts from here you can change the corner radius... this can get close to a circle, but you can't get a shape other than a rectangle/square. But if you increase the radius of the corner, then you will get a larger circle... Hope it helps
This worked beautifully....thanks.
Callout tags |
Thu, May 1, 2008 at 11:39:20 PM
12
callout only head |
Tue, Mar 26, 2013 at 7:09:20 AM
CALLOUT ISSUES |
Thu, Oct 9, 2008 at 3:34:15 PM
Rotate Callout Head? |
Thu, Aug 1, 2019 at 10:08:02 AM
Detail callout vs. Floor plan callout |
Mon, Nov 2, 2009 at 11:03:39 AM
