Forums >> Community >> Newbies >> sequential door tags?
Sun, Apr 13, 2008 at 8:50:17 PM | sequential door tags?
hmgirl
hi, i'm having trouble with door tags.  does revit number them sequentially in the project based on the order that they were placed?  my numbers jump around greatly is there any easy way at this point to renumber them sequentially in order and chose the door it begins?
Mon, Apr 14, 2008 at 9:26:26 AM | sequential door tags?
You should learn to use the search option of RevitCity as I am sure this has been covered several times before.  REVIT does number the doors sequentially  ....from the last door number YOU enterd  and it does so in the order of their creation - not when you finally choose to tag them.
The door utility program lcated here http://www.avatech.com/solutions/building-design/product-details.aspx?product=44
may be helpful to you.
More On Tags
Fri, Feb 3, 2012 at 9:06:59 AM
Schedule and Tags
Fri, Sep 23, 2011 at 2:32:25 PM
Door Tags
Mon, May 12, 2014 at 8:31:35 AM
Accessing Room Data in Door Tags
Mon, Jan 28, 2013 at 9:42:59 AM
Door tags and Door Type ID
Wed, Jul 10, 2013 at 1:40:25 PM
Page generation time: 0.2061
