Forums >> Revit Structure >> Technical Support >> Thickened slab edge
Sat, Apr 12, 2008 at 11:35:45 AM | Thickened slab edge
ksemple
1 Stars: 1 Votes
How do I change the shape of a slab edge?  Would there be any way to edit a profile to make it have a different shape and size?
Sat, Apr 12, 2008 at 8:45:14 PM | Thickened slab edge
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Hey ksemple,
An easy way to modify the slab edge profile is by selecting the profile through the project browser.
You select it this way because it would be considered a nested family. The profile loads into the sweep.
Just navigate your project browser to FAMILIES > PROFILES > SLAB EDGE - THICKENED.
From there just left click the size you want to modify and go into its properties, duplicate and change the dimension values.
You can create a new shape in a couple ways:
1. Right click on SLAB EDGE - THICKENED in the browser, pick EDIT, and that will open the aforementioned profile in the family editor. From there you can easily change the shape to what you need it to be.
2. FILE > NEW > FAMILY > PROFILE.rft then go into SETTINGS menu > FAMILY CATAGORY and PARAMETERS... and change the usage to SLAB EDGE. From there have fun creating your new family.
If you don't have much experience with families, I would go through the tutorials and take a look at how the factory created their profiles.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Mon, Apr 14, 2008 at 2:02:45 PM | Thickened slab edge
ksemple
1 Stars: 1 Votes
Thanks for the help
Fri, Jul 18, 2008 at 2:57:54 PM | Thickened slab edge
BigD
BigD Avatar
1 Stars: 1 Votes
I'm trying to use a custom slab edge.  I've followed the steps in the previous post (changed the usage to slab edge) and I've loaded the family into my project.  But when I click "slab edge" from the design bar, the custom slab edge family doesn't appear in the type selector.  what am I missing?
Fri, Jul 18, 2008 at 3:06:14 PM | Thickened slab edge
BigD
BigD Avatar
1 Stars: 1 Votes
just figured it out.  Sorry folks.  I'm such a moron.
Fri, Jan 27, 2012 at 1:08:45 PM | Thickened slab edge
SofiaClark
Thanks so much for the information!  Looked all over Autodesk WikiHelp and found NO help at all.  Appreciate the help!!
Sat, Jan 28, 2012 at 4:57:49 AM | Thickened slab edge
mcantwell
mcantwell Avatar
Note that if the material of the slab and slab edge match they merge seamlessly but they stay separate if the materials are different.
2 Thickened Slab Edges in ONE Foundation Slab
Mon, Jun 6, 2011 at 12:13:35 PM
Modeling thickened slab strip under bearing walls
Thu, Feb 5, 2015 at 1:13:00 PM
Creating slab edge...
Tue, Nov 4, 2008 at 3:36:02 PM
Thickened Slab Not Cutting Floor Line Out
Wed, Dec 28, 2011 at 7:54:13 AM
Thickened Slab Edge on Sloping Slabs
Thu, Apr 16, 2009 at 3:39:08 PM
Page generation time: 0.2821
