Forums >> Revit Building >> Technical Support >> revit rendering
Mon, Mar 21, 2005 at 11:19:33 PM | revit rendering
cpbc
3.5 Stars: 3 Votes
Hi! I am just trying the rendering ability in Revit. I have seen some good one on the gallery and I attempt to do likewise but the results is disastrous. Please advise. I am only using Raytrace and Sunlight.
Tue, Mar 22, 2005 at 5:11:15 AM | RE: revit rendering
fazerneil
4 Stars: 5 Votes
Rendering is a process you need to think about from the start of a project. You need to set materials/solid colours you require for each element. You then need to think about where to put viewpoint and sunlight in relation to your North point Dependant on processor etc, you need to think about the best settings you can attain. We have to leave our pc rendering overnignt, and if on a network, save all your info to local pc first as it will slow down over a network. The main quality of rendering can often come down to your dpi setting. Within view properties check your render image size is at least 300, 600 is better but sometimes dependant on what you are rendering does not make a lot of difference but will slow process down. It would be easier to make specific comment if you uploaded your jpeg image into the gallery. It may be clear to others what process you may be missing out. But always start at the tutorials.
Thu, Mar 24, 2005 at 11:16:46 PM | RE: revit rendering
winnwg
hi i'm also using revit 6.1 and find it to be a cool tool for presentation..however i cant get the results i want while rendering.. whenver i print my images out they come out very fuzzy or the colours are too dark. i also find it bery difficult to render good quality images.. can someone give me a good spec for a pc as i am going to invest in one .. just for revit.. thanks.. i use a PIV 3.06 with 712 mb ram, 64mb graphics card. could you tell me what seetings would be the best? thnks
revit rendering
Thu, Oct 14, 2010 at 8:33:24 AM
Revit MEP 2009 Rendering
Thu, Mar 5, 2009 at 8:35:55 PM
What is the best revit/rendering engine combo? [ 1 2 3 ]
Tue, Feb 3, 2015 at 9:40:52 AM
31
Revit 2009 Rendering Problem(Black screen) [ 1 2 ]
Mon, Apr 1, 2013 at 2:45:28 PM
27
Realistic Rendering [ 1 2 ]
Thu, Aug 4, 2011 at 2:30:37 PM
25
Page generation time: 1.3046
