Forums >> Revit Building >> Technical Support >> How to change a model from New Construction to Existing phase?
Fri, Apr 11, 2008 at 5:53:39 PM | How to change a model from New Construction to Existing phase?
JulieJ
I inadvertently drew much of a recent model on the new construction phase, when it is really an existing building that will be renovated.  Is there a quick way to change the entire model to the Existing phase?  Thanks!
Fri, Apr 11, 2008 at 7:04:28 PM | How to change a model from New Construction to Existing phase?
coreed
coreed Avatar
4 Stars: 16 Votes
Watch Video Below
http://screencast.com/t/1KjTwXSNZx
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Jun 29, 2009 at 12:51:17 PM | How to change a model from New Construction to Existing phase?
pepsiqueen
pepsiqueen Avatar
This does not seem to work in Revit 2010... anyone know how i can change an entire model to existing phase?
I'd rather be riding at whistler. or highland. thats good too.
Mon, Jun 29, 2009 at 1:12:57 PM | How to change a model from New Construction to Existing phase?
You shold be able to window in 3D and just change their properties all at once... unless some reside in non-editable worksets.  If so, you can unlock the puzzle pieces one at a time ... or just open all the appropriate worksets (own) and the you should be able to change them.
Thu, Jul 2, 2009 at 10:26:06 AM | How to change a model from New Construction to Existing phase?
pepsiqueen
pepsiqueen Avatar
The project is not broken into worksets, I am the only one in the office using revit at this time. When i select everything in the 3D view, the option to look at the properties of the elements selected is greyed out.
Thu, Jul 2, 2009 at 10:36:05 AM | How to change a model from New Construction to Existing phase?
Dgodfrey
4 Stars: 4 Votes
You inadvertently grabbed non-editable items as mentioned above. Select individual items such as a wall then select all instances, edit properties. Do it for all items. May take a minute or two. The other method is the 3D window then filter out all the non-editable items. Repeat.
Thu, Jul 2, 2009 at 11:09:16 AM | How to change a model from New Construction to Existing phase?
pepsiqueen
pepsiqueen Avatar
Since everything in the file is technically editable what is considered a 'non-editble' item? The filter dialog in the 3D view does not have an option to 'filter out all non-editable' There should by this time be a way to take an entire model and just say the entire thing is existing.
Thu, Jul 2, 2009 at 11:11:35 AM | How to change a model from New Construction to Existing phase?
Open your workset dialog box - there is a column called editable.  Change them all to yes.
Thu, Jul 2, 2009 at 3:33:22 PM | How to change a model from New Construction to Existing phase?
jarosa
jarosa Avatar
4 Stars: 5 Votes
If you select items such as text, dimension you will not be able to change phase for any of the items selected. Selecting in 3d views is one way to select only the model editable components or use filter to filter out the uneditable.
HTH
John
Fri, Jul 3, 2009 at 12:06:17 AM | How to change a model from New Construction to Existing phase?
Thread Post Kudo! Thread Post Kudo! #10
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Simple...Go to Settings>Phases>Select New Construction and then click on Combine with Previous. Everything Done. Later you can add your New Construction phase.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Wed, Nov 18, 2009 at 9:22:13 AM | How to change a model from New Construction to Existing phase?
Thread Post Kudo! #11
edelong
I'm going to piggyback on this older thread, since I have the same problem...
I've tried to select everything in 3D mode, but I'm not given any options to change the phase with everything selected.  The last comment about combining new construction with existing in the phasing dialogue seems to work, except that the graphics don't change to existing when view properties are set to "view all" (walls still hatched...nothing is "grayed out"Winking.  However, if I get properties on a wall, it shows up as being created in the existing phase.
I've made sure the graphic settings in the phase dialogue were set up correctly...any other ideas on how to get this to work graphically?
Wed, Nov 18, 2009 at 9:33:06 AM | How to change a model from New Construction to Existing phase?
edelong
Forget it...I figured it out.
In case you're in this same situation, the comment about changing the phase from the phase settings works...just make sure you add your new construction phase after you combined the with existing, and you'll have to switch all your view properties to show the new construction phase (it will automatically set all views to existing phase).
Wed, May 25, 2011 at 2:45:08 PM | How to change a model from New Construction to Existing phase?
#13
jjfosho
What do I do if I only want to move half of the objects on my "New Construction" phase to another phase?  Part of my building needs to go on a new phase, but the rest of it neerds to stay.  I want to be able to select a region of the building and move everything in that region to a new phase.
Wed, Oct 22, 2014 at 3:30:08 PM | How to change a model from New Construction to Existing phase?
#14
CADMonkey999
Select objects, Ctrl+X for Cut, and go to New Construction Phase and Paste Aligned to Current View.
New Construction phase cuts Existing Phase
Tue, Aug 9, 2011 at 12:21:57 PM
Translucent Existing Phase after Rendering
Sun, Sep 28, 2014 at 7:08:34 AM
Existing wall assembly visable in New Construction phase
Wed, Nov 2, 2011 at 5:49:09 PM
change default settings of phases?
Thu, May 3, 2007 at 11:06:15 AM
Revit Link Phase
Thu, Apr 17, 2014 at 12:04:42 PM
Page generation time: 1.4190
