Forums >> Revit Building >> Technical Support >> Joist Seat Elevation?? HELP!!
Fri, Apr 11, 2008 at 10:22:42 AM | Joist Seat Elevation?? HELP!!
TEC1
1 Stars: 1 Votes
can someone help please?  I'm running Revit Structure 2008 and when I place a joist between to beams/girders I notice the seat isn't sitting on the beam but rather the top of the seat is flush with the top of the beam.  Is there a setting I can change so that when i draw in a K-series joist the seat automatically gets placed on top of the beam flange as it should? Is it as simple as chaning the start/end level offset by the thickness of the seat?
Thanks Guys!
Fri, Apr 11, 2008 at 10:35:49 AM | Joist Seat Elevation?? HELP!!
maranelloboy
3 Stars: 2 Votes
Assuming the parameters for joists are the same in Revit Structure as they are in Revit Architecture, the only thing I can think of is to change the "z-Direction Justification" to "Other" and set the "z-Direction Offset" to match the seat height.  Not a perfect solution, but it's better than manually changing the bearing elevation at both ends of each joist.
Sloped joist seat
Wed, Oct 24, 2012 at 1:26:11 PM
Different seat depths same joist?
Wed, Nov 11, 2009 at 6:32:10 PM
bar joist seat depths
Mon, Nov 21, 2011 at 2:49:44 PM
Extended 2 1/2" joist end with a 5"+ seat bearing?
Thu, Sep 29, 2011 at 3:07:20 PM
Joist Top Elevation
Thu, Feb 27, 2014 at 8:58:17 AM
Page generation time: 0.2741
