Forums >> Revit Building >> Technical Support >> Door Legend Detail Tags / Callouts
Fri, Apr 11, 2008 at 7:20:52 AM | Door Legend Detail Tags / Callouts
jstephen
I am trying to add callouts/tags in my door type legend (on the door elevation) so I can detail the head and jambs.  Is there a specific tag that will do this and create a "callout viewport" to detail these elements?
THanks!
Mon, Mar 23, 2009 at 6:55:32 PM | Door Legend Detail Tags / Callouts
lhmodular
Here is a round about way to get the head / jamb / sill detail callouts to show up in a door or window legend:
-go into any drafting view, you can create a section callout here by selecting View>Section, then you can either create a new drafting view, or select an existing drafting view from the pulldown menu.
-then, select this section callout and cut it from the drafting view and paste it into your door or window legend.
Window Legend Detail Callouts
Sun, Jun 8, 2008 at 8:21:58 AM
View tags in legend
Tue, Feb 16, 2010 at 5:59:26 PM
Door/Room Tags in Callout Detail
Thu, May 17, 2007 at 3:18:42 PM
Curtain Wall Door as Legend Components
Mon, May 19, 2014 at 7:55:50 PM
Detail Callouts missing! Latest build didn't fix!
Thu, Oct 25, 2007 at 10:03:55 AM
Page generation time: 1.5162
