Forums >> Revit Building >> Technical Support >> Walls keep moving
Thu, Apr 10, 2008 at 2:59:28 PM | Walls keep moving
jeffe28
I am learning revit 9, and my walls keep moving.  the book I learned from didn't give good details of how to get the walls to lock permanetly, I know you can lock components to walls, but can you lock walls to the site?  I drew all the exterior walls, but when I move walls inside, the exterior walls move too.  I didn't know this was happening, and now my walls are not even close to the original dimensions; is it possible to get walls to never move- not just relations between walls and objects, but never move anywhere- ever
Thu, Apr 10, 2008 at 3:23:21 PM | Walls keep moving
jeffe28
So that is what that pin icon does!  I was calling it lock, but Revit calls it pin.
Thu, Apr 10, 2008 at 3:33:00 PM | Walls keep moving
Watch out !
You can over constraint your file and this will cause problems.
I usually on pin a few items and I only lock special demensions like for column grid and level dimensions.  What I do is use the disjoin button when I want to move something and assure myself that nothing goes with it.
Fri, Apr 11, 2008 at 4:37:20 AM | Walls keep moving
chiragpklg
4 Stars: 11 Votes
I totally agree with WWWHUB if u lock dimensions & levels, & try movin the objects with disjoin objects it takes care of ur model.
Regards,     Chirag C. Pawar    Cad Solution Application Engineer,    +91-9969866851     For KLGSystel  Limited,    301, Pujit Plaza, Plot No. 67,    Sector 11, CBD Belapur,    Navi Mumbai - 4000614,     Maharashtra, India.     Tel.:   +91 22 40916777.    Fax.:   +91 22 27576461.    Mob.:  +91 9969866851.    Email.: chiragp@klgsystel.com    Web.:   www.klgsystel.com
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Fri, Apr 11, 2008 at 10:04:17 AM | Walls keep moving
maranelloboy
3 Stars: 2 Votes
It sounds like you have your interior walls constrained to your exterior walls without your exterior walls having any constraint to keep them in place.
Typically what I do is lock only the main exterior walls to grids or ref. planes, and then dimension and lock those.  Locking and pinning everything will slow down and over-constrain your drawing.  I tried it once, and it was a bigger headache than having to move and realign everything when the design changed.
moving walls
Tue, Aug 6, 2013 at 8:54:03 PM
MOVING AND ALIGNING WALLS
Sat, Mar 10, 2012 at 5:57:39 AM
Walls moving/ disappearing ?!
Wed, Nov 2, 2011 at 2:37:01 PM
13
Electrical components moving when reloading arch model
Mon, Jan 5, 2015 at 9:01:02 AM
Walls keep moving
Wed, Aug 25, 2010 at 5:16:11 PM
Page generation time: 0.6296
