Forums >> Revit Systems >> Technical Support >> Manipulating Schedules
Thu, Apr 10, 2008 at 10:00:26 AM | Manipulating Schedules
Dimplesaur
I need to create a chart for my project with the Square footages of Residential units by floor.  I understand that you can make an area schedule that lists each unit and gives a level name, but I need a chart to look like the uploaded chart.  Is it possible to do this in REVIT, or do I need to do it in excel?  Our office is in transition into REVIT so the project was already started with a certain look that we need to keep.
Thu, Apr 10, 2008 at 11:23:57 AM | Manipulating Schedules
No, REVIT's schedules will not directly look like this becasue the schedules place the parameters in columns and the values below that.  Thus Unit name will be a column with 1A, 1B ... below that and Count is another column.
A workaround is to have multiple schedules side by side .... filtered and sorted to give you the same look.
Tue, Sep 16, 2008 at 1:14:57 PM
multiple schedules
Tue, May 1, 2012 at 1:04:42 PM
Schedules for Information In Schedules HAHA
Mon, Feb 13, 2012 at 12:08:12 PM
Schedules on multiple sheets
Thu, Apr 27, 2006 at 11:01:59 PM
Importing MS Word (or other text) into Revit
Wed, Jul 30, 2014 at 3:07:50 PM
Page generation time: 2.3243
