Forums >> Revit Building >> Technical Support >> question
Wed, Apr 9, 2008 at 2:02:47 PM | question
Tyshawna
I have a two story house and i'm currently working on the second floor. How do i get the first floor to show hidden lines lookin down from the second floor to the first.
Wed, Apr 9, 2008 at 2:27:45 PM | question
NancyHKA
in the second floor view, type "vp" (for view properties) and in the box, for "underlay", select the level of your first floor.
Wed, Apr 9, 2008 at 3:52:43 PM | question
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
If you are looking to print the lines below from the second floor, underlay the first floor>use the linework tool and select the desired lines below and change them to "hidden" linetype>then turn off the underlay. All that should show up is the hidden lines. FYI, these lines will not update when things change below, so you'll have to repeat this for any changes made on the first floor. So if this is to be used for documentation, its best to leave it until the end when things are less likely to change.
Brandon Pike | Owner/BIM Specialist
cad.web.print
website: http://www.thinkdesign-studios.com
blog: http://www.bimtionary.blogspot.com/
Worksets question - standards question...
Wed, Oct 21, 2009 at 7:28:40 AM
Computer Processor Question
Fri, Jul 21, 2006 at 9:49:48 AM
Revit Mechanical Equipment question VAV unit question
Mon, Oct 24, 2016 at 4:17:00 PM
Blue ? ( question mark) shared parameters [ 1 2 ]
Mon, Jan 17, 2011 at 1:17:42 AM
20
Revit 2012 - material tag "question marks" everywhere
Wed, Sep 13, 2017 at 9:26:13 PM
13
Page generation time: 0.2043
