Forums >> Revit Building >> Technical Support >> How to display N.T.S. with title on a Sheet?
Wed, Apr 9, 2008 at 2:00:31 PM | How to display N.T.S. as a scale on a Sheet?
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
I am working on a accessible sign detail that is not to scale (N.T.S.). When I put the detail on the sheet the scale that I am working in shows. Is there a way to override this? There isnt an 'Edit Family' available to me.
Thanks!
Edited on: Wed, Apr 9, 2008 at 2:01:19 PM
Wed, Apr 9, 2008 at 3:42:53 PM | How to display N.T.S. with title on a Sheet?
mhans
3 Stars: 10 Votes
Hi,
From File, Open,  select Annotations (from your imperial or metric Library), click View Title and save to another name. Edit your new Title view by deleting the Scale input and replace it with a Text entry instead of Label and write your text, N.T.S.. Select or make a prefered text size from your type selector if you like.
Motto: "No Post left behind"
Wed, Apr 9, 2008 at 3:51:44 PM | How to display N.T.S. with title on a Sheet?
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
I did all that... and loaded into project.
I select view on the sheet and go to the drop down box but its not there?
Wed, Apr 9, 2008 at 3:56:27 PM | How to display N.T.S. with title on a Sheet?
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
Nevermind I got it.
Just had to create a new 'type' in 'Element Properties' in my project. Duh.
 Thanks!
Mon, Mar 2, 2009 at 4:49:57 PM | How to display N.T.S. with title on a Sheet?
reqork
I'm a little lost on this one. How were you able to create a new type? Where did you do this at ?
Tue, May 10, 2011 at 1:33:31 PM | How to display N.T.S. with title on a Sheet?
mccoolj
mhans - thank you! This same issue was driving me nuts!
Tue, May 10, 2011 at 4:31:24 PM | reqork
need4mospd
Quoting reqork from 2009-03-02 16:49:57
"I'm a little lost on this one. How were you able to create a new type? Where did you do this at ?"
In the project browser just scroll down to Families/Annotation Symbols/View Title. Right click on View Title and click edit.
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:26 AM
Title Sheet text sent to back? or transparent?
Wed, Mar 4, 2015 at 3:25:00 PM
Viewport title locked. How to unlock?
Tue, Sep 30, 2008 at 3:20:48 PM
title on sheet
Thu, Aug 3, 2006 at 1:59:25 AM
revit 2018 manipulate the title block or sheet
Wed, May 30, 2018 at 2:11:37 PM
Page generation time: 1.4397
