12 Users Online (10 Members):
Forums >> General Discussion >> Revit Project Management >> How to change the color of materials
i would like to change the color of the outer walls and the color of the walls in the house. i also would like to learn how to change the color of some materials like kitchen cabinets and and cars.
To change the color in shading mode go to: Settings->Material, chose the material, and in the shading section you can change the collor. Note: You can unselect the "Update when AccuRender selection occurs" to avoid the collor change when you change the Texture.
WHAT??????????????????????? i dont get what u mean sorry
if you just want to change the material on certain surfaces you can use the paint bucket tool Click Link for Video http://screencast.com/t/mZNDSIHjOV
Edited on: Fri, Apr 11, 2008 at 12:10:58 PM
To change the color/material on your outer walls, click on the wall, bring up its Properties --> Edit --> Structure-Edit --> click where it says Material for the function you want to change (exterior or interior part of wall) --> then change the AccuRender to the material/color you want from the material library. You can use this way to do your interior walls, etc., too, along with the paint bucket tool mentioned by Coreed. Hint: Do some tutorials (or look in the getting started section) in your Revit program or tutorials on RevitCity ... they're a huge help : -)
2011 change material color [ 1 2 ] |
Sat, Aug 31, 2013 at 8:46:22 AM
16
Help a Newbie Out?? Materials and Color |
Sat, May 28, 2011 at 5:52:32 AM
How do you change the material and color of a download? |
Tue, Aug 6, 2013 at 7:31:46 AM
materials parameter doesnt work in project. |
Fri, Jul 24, 2009 at 10:32:02 PM
Materials Management HELP!! |
Tue, Jul 26, 2011 at 10:50:31 AM
