Forums >> General Discussion >> Wishlist >> WISHLIST - Cranked Sections
Wed, Apr 9, 2008 at 4:06:51 AM | WISHLIST - Cranked Sections
Suzanne84
It would be very useful to have sections that can be cranked - ie a section line that changes angle halfway through.
Wed, Apr 9, 2008 at 4:11:56 AM | WISHLIST - Cranked Sections
Suzanne84
While I think of it - elevations that you can manipulate also such as curved and cranked as for production drawings you need flattened elevations that can be measured from.
Wed, Apr 9, 2008 at 11:18:41 AM | Suzanne84
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting Suzanne84 from 2008-04-09 04:06:51
what do you mean by "cranked"
you already can have your sections make 90 degree turns thru your building
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Apr 9, 2008 at 11:40:01 AM | WISHLIST - Cranked Sections
Suzanne84
I need sections lines to bend in the middle at varying angles, I've got 3 blocks in a row in a building but each one is at a slightly different angle to the next, if I cut a section through all 3 blocks only one of them is perpendicular to the section, the other two are skew and walls etc show up thicker as they are being cut through diagonally. Ideally my section line would be able to bend twice to remain perpendicular to the blocks....hope that makes sense!
Thu, Apr 10, 2008 at 2:31:15 PM | WISHLIST - Cranked Sections
albertobalsalm
albertobalsalm Avatar
3 Stars: 1 Votes
I totally agree.  I wish you could have the section change angle partway through.  It is pretty annoying trying to line up seperate sections and elevations to make a fake continous one.
Cranked Rebar
Tue, Jun 23, 2009 at 1:30:43 AM
Cranked connections
Tue, Nov 10, 2015 at 1:22:14 PM
slanted model in place column
Mon, Nov 1, 2010 at 4:33:23 AM
Wishlist
Workflow & Implementation >> Chameleon
Wed, Apr 24, 2024 at 12:22:03 PM
AUGI Revit Wishlist
Mon, Oct 8, 2007 at 8:54:14 AM
Page generation time: 0.8133
