Forums >> Revit Building >> Technical Support >> Masking and filled regions dont cover dimensions and tags??
Wed, Apr 9, 2008 at 3:25:44 AM | Masking and filled regions dont cover dimensions and tags??
Dafpfy
3.5 Stars: 11 Votes
hi
'bring to front' doesnt seem to work, and a bunch of other idea's,,
i want to isolate a appartment to be able to print only one appartment at a time, any other ideas maybe ??
kind regards,
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Wed, Apr 9, 2008 at 7:03:26 AM | Masking and filled regions dont cover dimensions and tags??
That's right - they don't.
2008 - use hide element.
Wed, Apr 9, 2008 at 7:12:14 AM | Masking and filled regions dont cover dimensions and tags??
Dafpfy
3.5 Stars: 11 Votes
Does it work in 2009 ?
peace is the path."
Mahatma Gandhi.
Wed, Apr 9, 2008 at 8:37:55 AM | Masking and filled regions dont cover dimensions and tags??
Guess you'll have to wait to find out.
Wed, Apr 9, 2008 at 11:12:17 AM | Dafpfy
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting Dafpfy from 2008-04-09 03:25:44
hi
kind regards,
try this
1. select all the elements that make up the apartment you want to print
2. go to temporary/hide/islolate and select isolate element
3. then go back to temporary/hide/islolate and select  apply hide/isolate to view
you should be able to print now without any of the other elements printing
use the Reveal Hidden Elements to turn the other objects back on
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
Getting rid off masking regions?
Fri, Feb 4, 2011 at 4:12:56 AM
Filled Regions Not Masking?
Tue, May 12, 2009 at 5:45:16 PM
Masking Regions and Filled Regions BEHIND 3D Objects
Wed, Aug 1, 2012 at 8:10:27 AM
Exporting to Autocad with Masking Regions
Thu, Apr 25, 2013 at 10:33:27 AM
11
Page generation time: 0.3578
