26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Spot Elevation Leader
56 Posts No Rating |
Using 2008 is there a way to change the leader line type of a spot elevation? right now it is a solid line that attaches to the element. Can I change the line type to match the level line type? Thanks
I can't see anyway to change the line type, like you figured out, you can change the weight and the arrowhead...
Hide Spot Elevation Leader |
Wed, May 19, 2010 at 2:52:59 PM
border on a spot elevation tag |
Fri, Jan 29, 2016 at 2:52:39 PM
Spot Elevation Forced Text |
Fri, Apr 22, 2011 at 1:04:00 PM
Elevation Tag - Leader Problem |
Thu, May 17, 2012 at 5:48:20 PM
Spot Elevation vs. Level elevation |
Tue, Aug 19, 2025 at 1:06:15 AM
