Forums >> Revit Building >> Technical Support >> how to import revit 2008 data to autocad 2008????
Tue, Apr 8, 2008 at 1:08:30 PM | how to import revit 2008 data to autocad 2008????
sharath
means if i import cad files from revit 2008 to cad 2008 and make dimentions to match that of revit files it doesnt come properly and if i explode the dwg file it actually becomes all messed up....so please help me
Tue, Apr 8, 2008 at 10:12:03 PM | how to import revit 2008 data to autocad 2008????
eldados
eldados Avatar
4.5 Stars: 8 Votes
in Autocad go to Format--> Dimension styles... you can change the appearance of your dimension from the Revit export.
do not explode the dwg.
does this help?
Integrator
KarelCAD
exporting to autocad 2008
Wed, Mar 24, 2010 at 1:24:34 PM
Importing AutoCAD MEP 2008 files into Revit Architecture 2008
Fri, Nov 16, 2007 at 1:27:47 PM
Structure Suite 2008
Tue, Apr 17, 2007 at 3:19:52 PM
import to revit from autocad
Sun, Mar 31, 2013 at 11:37:12 AM
Converting Autocad files to Revit 2008
Tue, Dec 4, 2007 at 1:03:30 PM
Page generation time: 1.6184
