Forums >> Revit Building >> Technical Support >> Lost Solid Fill Pattern
Tue, Apr 8, 2008 at 10:11:06 AM | Lost Solid Fill Pattern
mlennon
While working on a fairly large Project (450,000 sf) we have somehow changed our hatch pattern for the default "solid fill pattern" in Revit. Now the fill pattern for "Solid Fill" is a diagonal down pattern. I cannot figure out how to change it back to solid fill pattern.
Any help would be greatly appreciated!
Thanks!
Tue, Apr 8, 2008 at 4:49:00 PM | Lost Solid Fill Pattern
TABEST
4 Stars: 4 Votes
quite simple, open up your project, then open up a default project.  with your project in the window, go to file->transfer project standards, and then transfer only fill regions... This will fix your problem, do beware, it will want to overwrite any default hatches that you might have modified or renamed...
Wed, Apr 9, 2008 at 7:58:47 AM | Lost Solid Fill Pattern
mlennon
Thank you very much!
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Solid Fill Pattern
Wed, Jan 9, 2008 at 1:55:24 AM
Revit 2015 Solid Cut Fill Pattern
Thu, Sep 22, 2016 at 8:27:54 AM
Solid Fill Hatch
Sun, Apr 1, 2007 at 8:56:31 PM
Fill Pattern
Mon, Jun 5, 2006 at 8:13:21 PM
Page generation time: 4.4832
