13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> window absent in elevations
The window circled in plan view is visible in 3d view (elevation in color) but not in relevant building elevation (elevation in black&white) unless i hide the opening in the wall in front of it. And there is an apperant difference in shadowings of the elevation and 3d view oriented to an elevation direction. What might be the problem with my building elevation view?
in the family, verify that when you click on the opening, that it is transparent in elevation views also... (once you click on the opening, this checkbox appears on the options bar).
thx for the quick reply. it worked! But it seemed strange to me that if is it by default this option is left unclicked?
yup, it is ALWAYS left unchecked, so be sure to check it every time, and I'm in agreement, it should be checked by default.
Maybe the reason is to avoid showing unnecessary lines inside the openings, such as an edge of a cabinet or door inside.
Plumbing Absent in Elevations, Sections & Perspectives |
Thu, Apr 30, 2015 at 4:27:03 AM
Multiple Views Deleted in Central File - Please Help! |
Fri, Apr 1, 2011 at 8:03:36 AM
What are people using window elevations? |
Thu, Jan 31, 2008 at 9:44:56 AM
how to add elevations to door & window schedules |
Tue, Oct 30, 2007 at 11:59:24 AM
Window Elevations |
Fri, May 18, 2007 at 5:18:02 PM
