Forums >> Revit Building >> Technical Support >> Change appearence of lines
Tue, Apr 8, 2008 at 4:28:09 AM | Change appearence of lines
DagensSallad
Im drawing firewalls in a projekt and whant the lines to look dash-dotted, but not with the rounded corners which is created. I want sharp corners on dashes and dots. Can i change that in a linetype? Kinda like when you change your pen in "paint" or something from round to square.
Tue, Apr 8, 2008 at 6:29:17 AM | Change appearence of lines
I don't like REVIT's rounded endpoint on lines either but taht's what we have.  You could do multiplke lines side by side or maybe a square filled region at endpints and corners....
Neither one a good solution.  We have decided to live with it for now.
Adjusting footing appearence.
Wed, Feb 10, 2016 at 9:35:06 AM
HOW do I render my floor panelling to look like realistic woodgrain?
Fri, Oct 22, 2010 at 5:25:31 AM
Linestyles of Model Lines Change Depending on Phase
Wed, May 20, 2009 at 4:13:04 PM
Help!!!!! Families not everwriting
Thu, Feb 26, 2009 at 3:42:38 PM
rendering light through curtain walls
Tue, Nov 16, 2010 at 3:31:24 AM
Page generation time: 2.9981
