18 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> twin height brick pattern
I'm looking for a twin height brick model pattern. 240mm long x 160mm high.
Macca Sunshine Coast QLD Australia |
Just edit another pattern, these are just a text file. You should be able to dowload one of the model brick patterns here and be able to identify the different x & y dimensions in that. Then just change those, save the file to a new name and load it. It's very easy to do so taling the time to learn it now will pay good dividends later.
Pattern brick wall |
Thu, Nov 17, 2011 at 7:15:35 PM
Help with brick hatch |
Mon, Oct 27, 2008 at 5:39:36 PM
11
Rendering - Brick looks like a stone pattern |
Fri, Jun 17, 2011 at 12:48:59 PM
brick pattern not consistent |
Wed, Mar 16, 2011 at 1:22:14 PM
Mixing of brick and block patterns and not aligning |
Fri, Jun 23, 2017 at 9:40:16 PM
