Forums >> Revit Building >> Technical Support >> Problems establishing linetypes
Mon, Apr 7, 2008 at 10:33:22 AM | Problems establishing linetypes
MARS1276
1 Stars: 1 Votes
I am working in a plan view in which I am showing my foundation structural wall and the view below shows my 'Top of Footer' level as well.   My problem is that I cannot seem to change the linetype for the view below to make my footing show as hidden lines.  I have tried changing my line within the Visibility/Graphic Overrides dialogue menu, but that didn't work.
What am I not doing here that I need to do so I can change the display of my linetype in the 'Top of Footer' view below?
Mon, Apr 7, 2008 at 12:51:38 PM | Problems establishing linetypes
MARS1276
1 Stars: 1 Votes
Thanks rcobbjr!  I was having the exact same problem and this fixed it for me as well.  A couple questions though, will this change the default settings for Revit to use the hidden linetype for anything below or will it simply be a global change per project?  How could I go about changing the default settings for Revit to do this if I needed to?
the link to the forum that answered my question can be found here:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=9259
DWG Revit export replacing linetypes with erronous linetypes
Tue, Mar 17, 2015 at 10:07:42 AM
Complex Linetypes in Revit?
Mon, Jul 2, 2012 at 1:51:38 PM
Getting CAD Linetypes into REVIT
Thu, Jul 24, 2008 at 7:11:10 PM
Linetypes and Phases
Thu, Dec 1, 2005 at 5:29:34 PM
Custom Linetypes
Wed, Nov 7, 2007 at 5:53:17 PM
Page generation time: 0.1459
