Forums >> Revit Building >> Technical Support >> Messing levels together?
Mon, Apr 7, 2008 at 8:20:44 AM | Messing levels together?
jenks
1 Stars: 1 Votes
I have the house foundation which is 8' tall on an 8" footing on one level and then I have the garage wall, 4' high, on a 8" thick footing on another level. I want the students to print off the foundation plan. we cannot get all of the footings and walls to show up because they are on different levels. Is there away to mess levels together?
Thanks.
Jack
Mon, Apr 7, 2008 at 8:42:05 AM | jenks
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting jenks from 2008-04-07 08:20:44
Thanks.
Jack
take at look at adjusting the view range for the upper level to display the info on the lower level or create a new view where you show the info from both levels combined.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Apr 7, 2008 at 8:50:27 AM | Messing levels together?
maranelloboy
3 Stars: 2 Votes
Use a plan region around the area that's not showing up.  You can set the view range specific to that region.
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
Levels missing Revit 2012 [ 1 2 ]
Mon, Sep 28, 2015 at 3:29:41 PM
19
Levels, Disappeared. [ 1 2 ]
Sun, Sep 24, 2017 at 7:44:33 AM
16
Floor levels slightly offset
Mon, Nov 5, 2012 at 10:23:46 AM
walls look different on different levels
Thu, Mar 11, 2010 at 2:38:19 PM
Page generation time: 1.6258
