Forums >> Revit Building >> Technical Support >> Annotations and text
Sun, Mar 20, 2005 at 12:03:27 AM | Annotations and text
ridhs
hi. i was wondering if there is a way i can change the size of the text that appears for the grid callouts and the text that appears for the sheet title?
Sun, Mar 20, 2005 at 6:47:33 PM | RE: Annotations and text
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Edit or create new grid head and view title families, then load in, and substitute those for the unwanted ones. HTH.
Mon, Mar 21, 2005 at 6:13:45 AM | RE: Annotations and text
saumya
ok.anyhting in revit is family dependent.starting from your walls to door to roof.So if you want a different type of a thing you got to make a family of it.once you have a family, you can use it anywhere.So the same holds good for annotaions too.make some families of your annotaions and save it.next use them where you want them as you use different elements in Revit.That means you have to create different familes for different sizes too. saumya
Text Masking in annotations
Tue, May 10, 2011 at 10:38:55 AM
Family w/ nested annotations- controlling parameter visibiliity
Fri, Apr 18, 2014 at 8:48:59 AM
Annotations, Labels or Tags
Wed, Aug 25, 2010 at 4:27:31 PM
Linked Revit Model Annotations
Mon, Jul 20, 2009 at 4:15:26 PM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
Page generation time: 0.1819
