Forums >> Community >> The Studio >> Wall acting like railing
Sun, Apr 6, 2008 at 3:35:15 AM | Wall acting like railing
architurk
architurk Avatar
3.5 Stars: 3 Votes
Anybody have ever thought about a wall structure acting in railing principals? It would really ease my work if i could put a column in a wall structure as "baluster" is in railing system, and a wall sweep profile as "rail" in railing. I work on proposal of a fence wall surrounding a great complex, which i have circular walls and intersections of varrying angles. So once i figure out a railing system for wall, i would simply draw the outside line scketch and thats it!
Wed, Aug 20, 2008 at 3:05:36 PM | Wall acting like railing
cganiere
cganiere Avatar
I've used railings for fences. I never thought of it as a wall replacement. As long as you don't want to place doors or windows in your railing/wall you'll be fine.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG
Fri, Sep 12, 2008 at 11:23:18 AM | Wall acting like railing
tim123
4 Stars: 19 Votes
You can do this with walls if you go into the wall edit structure mode and click the preview button, bottom left and choose section.  Profiles can now be inserted horizontally at any height and offset.  To insert vertical elements in normal mode insert a wall sweep and click the vertical button on the options bar.
Making quick fence wall using railiing system
Tue, Apr 8, 2008 at 10:21:06 PM
wall railing for ramp
Wed, Dec 18, 2013 at 1:52:55 PM
Wall Based Railing
Tue, Jul 5, 2016 at 10:42:23 AM
Sloped railing along a wall
Sat, Oct 27, 2012 at 6:59:21 AM
Getting Cut Wall Hatch to move WITH the Wall
Fri, Aug 10, 2012 at 2:59:50 PM
Page generation time: 2.4958
