Forums >> Revit Building >> Technical Support >> 3mb memory switch
Fri, Apr 4, 2008 at 8:40:26 AM | 3mb memory switch
drawler
I had a thread called 'import/link, manage links...' explaining that my entire hard drive crashes when I link or manage links of dwg files in revit.  The suggestion of the 3mb memory switch was given, but that didn't help.  Would it help to create a 4mb switch?  I need to resolve this problem so I can perform this basic and essential procedure asap!  Please help!
Fri, Apr 4, 2008 at 9:23:06 AM | 3mb memory switch
Sorry, I said 3 mb when I should have said gb - here is the link http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=8018966&linkID=9243099
Fri, Apr 4, 2008 at 9:23:59 AM | 3mb memory switch
coreed
coreed Avatar
4 Stars: 16 Votes
if the 3GB switch didn't work, i don't think creating a 4GB switch would do any good or even possible on your system unless you have more tha 4GB of memory installed on your system. but i could be wrong and it won't be the first time.
i would remove all the autocad linked files from Revit.  then run an autocad audit on all the autocad files that your are trying to link and then purge them clean. then  re-link these files into Revit and see if that helps. thing like this are some times hard to resolve.
point-and-case, take a look at this post. how they figured this out other than trail and error bets me.
http://hokcadsolutions.blogspot.com/2008/04/slab-editing-edit-cut-profile-issue.html
put in a request w/ Autodesk and your re-seller for help
HTH
Edited on: Fri, Apr 4, 2008 at 9:25:18 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Apr 4, 2008 at 9:33:12 AM | 3mb memory switch
drawler
Thank you for the suggestions.  I appreciate your help!
3GB memory switch
Mon, Apr 7, 2008 at 5:41:13 AM
Revit crashes when i go to "File- Open" WHY!?
Fri, Apr 4, 2008 at 8:36:12 AM
Revit Question
Mon, Oct 15, 2012 at 7:25:17 AM
I can't assign a switch ID to a switch
Wed, Dec 9, 2020 at 5:42:46 PM
Video cards that work with 2009 & 3 meg switch
Thu, Oct 30, 2008 at 2:45:25 PM
11
Page generation time: 1.9390
