22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Autocad text justification
I have imported a wall section from autocad into Revit 2008, but there is a problem the next justification. I have tried doing a "save as" in autocad to difference version, but nothing seems to help. This is driving me nuts! Any thoughts?
try to export the file into cad formats than save in autocad may be this can help u. Regards, Chirag C. Pawar Cad Solution Application Engineer, +91-9969866851 For KLGSystel Limited, 301, Pujit Plaza, Plot No. 67, Sector 11, CBD Belapur, Navi Mumbai - 4000614, Maharashtra, India. Tel.: +91 22 40916777. Fax.: +91 22 27576461. Mob.: +91 9969866851. Email.: chiragp@klgsystel.com Web.: www.klgsystel.com
Chirag C. Pawar Cad Solution Application Senior Engineer KLGSystel Ltd. India 301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel .: +91 22 409 16777. Extn. - 718Fax .: +91 22 275 76461.Mob .: +91 99 698 66851.Email.: chiragp@klgsystel.com Web .: www.klgsystel.com |
"try to export the file into cad formats than save in autocad may be this can help u." ? the wall section started in autocad dwg. export what file?
Imported / exploded AutoCAD files can be memory hogs so be carful and don't use them unless you clean them up first. If you plan on exploding the file, then in AutoCAD, you want to delete all all arrow heads, leaders, hatches and polylines that may have small arcs. I also like to put all lines of the same type on seperate layers reducing my layers to just a one or two. When you explode the file, REVIT will create new linetypes named by layer. You can then delete that linetype and all of the lines will become thin lines which you can then pick and assign to other types as needed. All of your text will come in as individual lines of text. I like to copy paste multiple lines back together to make single REVIT text entities which you can then add leaders to and formate L/M/R as appropriate. Hope this helps.
Revit Exporting to Autocad Changes the Justification and Margines of Texts |
Sat, Jan 16, 2021 at 7:06:11 AM
Text Editing (Justification) |
Tue, Jun 19, 2007 at 5:47:06 PM
Changing text families |
Tue, Dec 2, 2008 at 5:22:46 PM
justification problems creating general notes. |
Mon, Sep 21, 2015 at 9:24:19 AM
tEXT jUSTIFICATION |
Wed, Jun 20, 2018 at 11:10:09 AM
