15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> 90 Degree Curved Stair possible??
43 Posts No Rating |
I am wonderin gif it is possible to make a curved stair way curve a full 90 degrees? I am trying to make curved stairs, but Revit makes either the top or the bottom of the stairs 90 degrees, not both. Anyone have any ideas on how to make a 90 degree curved stair? Thanks
Revit user since 2008. |
Hi, you have two choises: 1º create boundary and riser just like the 1-image attatch or 2º with Run create a stair with arc then click the blue line change the angle to 90º and in the properties you must adjust the maximum riser height 2- image attatch. This is what you want?
one option would be to use the boundary option and draw your boundaries first and then add the risers
thanks for the input. Typhoon: I am trying to acheive exactly what you came up with in image 2. I will give it a try. thanks
What I do for my curved stairs is use the boundry function. I started out by doing a radial array of ref. planes to mark the risers. Use the arc length function in the dimension command to check that your tread depths are code-compliant (the smaller your radius, the bigger the angle between risers you will need). Draw your side boundries and then draw a riser on each ref. plane.
SHnail It looks like your run requirement is not long enough. We had to sit down and play with it for a while to get the stair to come out at a perfect 90. In the end it is easier to do what Maranelloby sugests by creating a series of ref planes for the risers and using a boundry. Nick
Curved Stair Question |
Mon, May 7, 2007 at 2:10:41 PM
curved stair attactched to wall |
Sun, May 31, 2009 at 2:46:48 AM
Stair has strange curved underside |
Thu, Aug 31, 2017 at 9:16:25 AM
Curved Stair higher than 4m |
Wed, Jun 3, 2009 at 11:15:02 AM
curved stair |
Thu, Apr 29, 2010 at 12:11:16 PM
