Forums >> Revit Building >> Technical Support >> Rendering in revit using the accurender - is it worth
Thu, Apr 3, 2008 at 2:28:24 AM | Rendering in revit using the accurender - is it worth
dominik85
I am rendering in a image in Revit using the built in accurender. how do i import other materials into the program.
Is it worth spending time trying to render an image in revit and not exporting it to 3d max(haven't used it before)
Need an answer quite quiclky...
Thanks
dz
Wed, Apr 9, 2008 at 7:27:17 PM | Rendering in revit using the accurender - is it worth
TABEST
4 Stars: 4 Votes
NO,  if you are going to export your model to an external renderer, then assign the materials there.  If you can wait until 2009 comes out, then I'd try rendering it from Revit, as the rendering quality seems to be much improved.  But even more important than any and all of the above is what are you used to using?  If you are a wiz in some rendering engine, then don't use Revit, if you don't have any skills in some other rendering engine, then use Revit.  But as I said, if you have time, wait on it, because when 2009 ships, if you are going to it, everything that you do in 2008 (accurender) is wasted, as it doesn't translate.  So don't set the materials for your building twice!
Thu, Apr 10, 2008 at 7:27:15 AM | Rendering in revit using the accurender - is it worth
chiragpklg
4 Stars: 11 Votes
I would prefer to go for 3dsMax, if u know it well, cause it gives more realastic output, or rather as TABEST says wait 4 revit 9
Regards,     Chirag C. Pawar    Cad Solution Application Engineer,    +91-9969866851     For KLGSystel  Limited,    301, Pujit Plaza, Plot No. 67,    Sector 11, CBD Belapur,    Navi Mumbai - 4000614,     Maharashtra, India.     Tel.:   +91 22 40916777.    Fax.:   +91 22 27576461.    Mob.:  +91 9969866851.    Email.: chiragp@klgsystel.com    Web.:   www.klgsystel.com
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
IS ACCURENDER NXT PLUGIN WORKING ON YOU REVIT 2009?
Tue, Nov 25, 2008 at 6:29:33 AM
Accurender
Fri, Dec 1, 2006 at 6:34:49 AM
Looking for Rendering Suggestions on a Revit 2008 Accurender Rendering..........
Wed, Nov 4, 2009 at 4:41:36 PM
ACCURENDER
Mon, Feb 19, 2007 at 3:16:52 PM
Revit can't find Accurender?
Fri, Nov 30, 2007 at 11:09:43 PM
Page generation time: 1.6795
