Forums >> Revit Building >> Technical Support >> Creating a wall type with vertical sweeps/reveals/??
Wed, Apr 2, 2008 at 2:18:23 PM | Creating a wall type with vertical sweeps/reveals/??
gheidt
Is there a way to create a wall type with vertical sweeps or reveals in the wall edit assembly?
I want to create a wall that has the sweep I created to form the metal siding.  To do doors and windows, I had to create an opening and a wall behind the metal siding to make everything look allright.
Tue, Apr 8, 2008 at 3:00:14 AM | Creating a wall type with vertical sweeps/reveals/??
chiragpklg
4 Stars: 11 Votes
well i have attached an image just have a look & do reply me if u r looking 4 such solution than i shall give u the correct method to od the same.
Regards,
Chirag C. Pawar
Cad Solution Application Engineer,
+91-9969866851
For KLGSystel Limited,
301, Pujit Plaza, Plot No. 67,
Sector 11, CBD Belapur,
Navi Mumbai - 4000614,
Maharashtra, India.
Tel.: +91 22 40916777.
Fax.: +91 22 27576461.
Mob.: +91 9969866851.
Email.: chiragp@klgsystel.com
Web.: www.klgsystel.com
Chirag C. Pawar
Cad Solution Application Senior Engineer
KLGSystel Ltd. India
301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel    .:    +91 22 409 16777. Extn. - 718Fax   .:    +91 22 275 76461.Mob  .:   +91 99 698 66851.Email.:    chiragp@klgsystel.com
Web  .:    www.klgsystel.com
Tue, Apr 8, 2008 at 3:01:00 AM | Creating a wall type with vertical sweeps/reveals/??
chiragpklg
4 Stars: 11 Votes
oops i forgot to attach the image. here it is
Chirag C. Pawar
Tue, Apr 8, 2008 at 10:25:16 AM | Creating a wall type with vertical sweeps/reveals/??
TABEST
4 Stars: 4 Votes
horizontal yes, vertical, unfortunately no.  but if you design your sweep to go horizontally, and it is just very "wide", you can take up the whole wall with a pattern much like what you had shown.
Precast panels and vertical reveals
Thu, Jan 17, 2013 at 9:38:52 AM
Vertical Reveals for Running Bond Pattern
Thu, Sep 3, 2009 at 8:20:46 AM
Vertical Wall Reveals not cutting sweep
Wed, Nov 8, 2006 at 9:23:11 AM
Vertical chamfers on precast panels
Tue, Oct 25, 2011 at 4:31:49 PM
Wall sweeps to deep reveals
Tue, Jan 11, 2005 at 4:07:26 AM
Page generation time: 1.7026
