Forums >> Revit Building >> Technical Support >> Material Take Off Formula for length of studs at sloping wall?
Wed, Apr 2, 2008 at 10:13:18 AM | Material Take Off Formula for length of studs at sloping wall?
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
When you attach a wall type at a gable to a sloping roof you end up with a varying wall height.  Is there a handy-dandy formula for calculating the length of studs when the wall height is increasing?
Improper use of Boolean Expression message with my calculated value formula
Thu, Jan 30, 2014 at 3:31:03 PM
Precast embed connections
Wed, Jul 30, 2008 at 11:22:13 AM
'Inconsistent units" error in parameter formula; length vs integer
Fri, Dec 13, 2013 at 10:37:04 PM
need help with a formula for my calculated value
Thu, Jan 30, 2014 at 1:03:02 PM
Variable Length Family with Array Formula
Wed, Aug 8, 2012 at 9:56:46 AM
Page generation time: 0.6936
