13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Problem w display of floor patterns over diff. levels
1 Posts No Rating |
Forgive me if this topic has been covered before.
I have a simple project (3000 sq ft) but split over 5 levels, each 3-4 feet above/below the next. My problem is the floor plane from one of my lower levels shows up in the next level up, and another floor doesn't show up at all in the correct plan view. Also, the floor pattern runs right over some casework that I dropped in. It's as if the floor is on the wrong level, but it's not.
In elevation/section and in 3d the floor shows correctly. The properties show it on the right level too.
If anyone has any insight into this problem, I would really appreciate it.
2 Posts No Rating |
Hello Mr. Clayr
I can give solution for your second Question "The floor pattern runs right over some casework". Open the casework family which u have placed on the floor. Select any component of the family and click "Visibility...." on the option bar, there under "Display in 3D views check the box adjacent to "Plan/RCP" and "When cut in Plan/RCP" and click OK. Save the file and reload it in your project. I am sure your problem is solved.
For further questions you can send me a mail to pvennapusa@yahoo.com
Regards
Pavan
2 Posts No Rating |
Hello Mr. Clayr
I can give solution for your second Question "The floor pattern runs right over some casework". Open the casework family which u have placed on the floor. Select any component of the family and click "Visibility...." on the option bar, there under "Display in 3D views check the box adjacent to "Plan/RCP" and "When cut in Plan/RCP" and click OK. Repeat this procedure for all remaining components in that family. Save the file and reload it in your project. I am sure your problem is solved.
Regards
Pavan
Floor patterns diff directions same pattern. |
Sun, Sep 27, 2009 at 4:57:09 PM
Revit 2020 - Stairs not showing in plan levels |
Sun, May 29, 2022 at 7:23:51 PM
Spot levels on external floor family |
Fri, Aug 17, 2007 at 2:44:13 AM
Floor levels slightly offset |
Mon, Nov 5, 2012 at 10:23:46 AM
create a filter for floor surface patterns below |
Mon, Dec 3, 2018 at 6:51:01 AM
