Forums >> Revit Building >> Technical Support >> crop region visible
Tue, Apr 1, 2008 at 6:20:46 AM | crop region visible
drawler
Within the view properties, I have the crop region visible turned on, but do not see the box to adjust the size of the view. It works fine in plan, but not in elevation. Please help with any suggestions! Thank you. (I use Revit Architecture)
Tue, Apr 1, 2008 at 6:41:31 AM | crop region visible
This is view property of the view - not the sheet so if you have placed the view on a sheet, you have to activate the view first then do VP and make sure crop regions are on and visible.
Tue, Apr 1, 2008 at 6:54:42 AM | crop region visible
drawler
Thank you, WWHub.  That was the procedure that I had followed, with no luck.  But with your suggestion, that lead me to go to the directly to the actual view rather than activate the view on the sheet.  I saw that the cropped region was there, but was dashed.  I think this is because it is a dependant view with a match line.  It sure would be nice to see this when you activate the view on the sheet.  Thanks again WWHub.
Crop Regions Disappear When I Assign a View Template
Sun, Apr 22, 2018 at 11:04:20 PM
Annotation Crop boundary is not visible
Mon, Sep 24, 2012 at 3:16:13 PM
crop region
Fri, Feb 25, 2011 at 1:21:49 PM
Revit Text Element Appearing Outside Crop Region
Fri, Nov 22, 2013 at 7:37:04 AM
12
Step matchline with crop region?
Wed, Sep 5, 2007 at 5:05:22 PM
Page generation time: 2.3158
