Forums >> Revit Systems >> Technical Support >> Title Blocks
Sun, Mar 30, 2008 at 6:45:08 PM | Title Blocks
DMP65
I'm new to REVIT MEP and setting up my titleblocks.
I have added some labels into the title block but am not sure how to set up more than one line for the "Project name" or "Client Name"
Sun, Mar 30, 2008 at 7:27:19 PM | Title Blocks
NKramer
4 Stars: 9 Votes
There are 2 ways of going about this. One you can stretch the label geometry in the actual label family to the desired length. This could require untold number of labelfamilies (1/8" Arial 5" long, 2/16" Arial 5" long, etc, etc.)
Or you can be sure that your label is long enough for your longest label and then use the TTF/ charaector map short cut of holding ctrl + hit enter. This will work in MOST cases. However, it does not work for sheet names and a few other instances. Also you will only see the 1st line of text in schedules. But it wrks great for labels within families.
HTH
Nick
Delete or Purge out Title Blocks?
Wed, Nov 26, 2008 at 5:06:00 PM
Customize new Title Blocks
Mon, Sep 21, 2009 at 2:55:19 PM
Sheets Title Blocks
Mon, Jul 6, 2015 at 2:30:16 PM
Title blocks
Mon, May 11, 2009 at 2:53:44 PM
creating custom title blocks
Tue, May 22, 2007 at 2:29:40 PM
Page generation time: 6.2134
