13 Users Online (10 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Exporting Electrical panel schedules to Excel
Fri, Mar 28, 2008 at 11:19:31 AM | Exporting Electrical panel schedules to Excel
mtrmcemjrsfr
Does anyone know if it is possible to export panel schedules created by Revit to excel format?
Thanks,
mtrmcemjrsfr
Wed, Sep 24, 2008 at 1:09:23 PM | Exporting Electrical panel schedules to Excel
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello there,
If you are merely trying to get a schedule into excel format, you don't need OBDC.  All you need to do is got  to your schedule.  Then go to file>export>schedule.  It'll save it as a delimiter text file.  Then go to Excel.  Go to Data>import external data...>import data.  Go find your .txt delimiter text file and you'll get a few dialogs to edit your excel layout.  I just leave as default, and click finish.  You'll see all your schedule in.
 Now you'll probably have to edit it a bit as you lose merged cells etc.  But a lot easier than typing it out!
Hope that helps,
Lorne
Denver, CO
Revit Architecture
Wed, Sep 24, 2008 at 6:23:47 PM | Exporting Electrical panel schedules to Excel
mtrmcemjrsfr
I tried to do that and in File>Export>Schedule, Schedule was not available, (Grayed out). I had the panel schedule opened but it didn't work. What else do i need to do?
Thanks,
Mike
Wed, Sep 24, 2008 at 6:29:30 PM | Exporting Electrical panel schedules to Excel
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
hrmmm well that stumps me.  I went to my door schedule and it worked fine.  I would say just make sure your schedule is the active window and also make sure it's a Revit schedule.  Not a legend or drawing view.
Make sense?
Denver, CO
Revit Architecture
Wed, Feb 18, 2009 at 2:28:36 PM | Exporting Electrical panel schedules to Excel
SamLerman
Exporting is nice, but what is the use of it, if you can't import Excel file back to Revit?
Or, maybe I don't know how?
I'm trying to link AutoCAD file with linked Excel schedules, it does not work, Revit don't take schedules.
Maybe I do something wrong?
Wed, Feb 18, 2009 at 2:53:31 PM | SamLerman
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Quoting SamLerman from 2009-02-18 14:28:36
Well the only use I see, is when you need to send your door/window schedule to say a consultant to edit it and they don't have Revit.  I don't know how to import back into Revit, as the schedule is linked to actual model objects so I don't think it's possible (not for sure).
As for autocad, I try not to use it.  So I can't help you there.  Sorry.
Denver, CO
Revit Architecture
Exporting Multiple schedules to excel at once?
Wed, May 21, 2008 at 10:11:07 AM
Exporting Schedules into excel format
Fri, Mar 13, 2015 at 5:53:44 AM
exporting to excel
Mon, Feb 6, 2012 at 6:26:26 AM
electrical panel schedules in 2011
Fri, Oct 22, 2010 at 12:11:22 PM
Electrical Panel Schedules - Space numbers
Wed, Sep 3, 2014 at 2:49:40 PM
Page generation time: 7.3816
