Forums >> Revit Building >> Tips & Tricks >> Importing a title block from cad
Fri, Mar 28, 2008 at 9:19:21 AM | Importing a title block from cad
ljromero
hey can anybody enlighten me on how to import an autocad title block into revit?
Fri, Mar 28, 2008 at 10:46:42 AM | Importing a title block from cad
You can only import the 2d geometry - not any attributes.
Look up sheet in your help menu and it will tell you how to set up a titleblock.  You can also lookup import to see how to import the cad file into your sheet family.
Fri, Mar 28, 2008 at 10:56:10 AM | Importing a title block from cad
ljromero
thanks that helps a lot.  I was searching for title blocks, but the help menu wasn't very helpful.
Fri, Mar 28, 2008 at 11:12:04 AM | Importing a title block from cad
R E A D  my post.  I said look for sheet!  In that area you will learn about titleblocks.
Fri, Mar 28, 2008 at 11:55:35 AM | Importing a title block from cad
ljromero
yeah I got it man... Thanks!
Importing CAD to REVIT (vs. 2014)
Mon, Nov 24, 2014 at 4:03:43 PM
Importing Arch. Title block with all info.
Mon, Mar 30, 2009 at 4:55:02 PM
How to import my title block from AutoCAD?
Mon, Sep 10, 2007 at 4:25:43 PM
12
Titlte Block causing plot issue
Fri, Apr 20, 2012 at 1:59:34 PM
Font on Title sheet absent from project Title Block
Thu, Sep 15, 2022 at 12:31:26 PM
Page generation time: 1.2416
