Forums >> General Discussion >> Revit Project Management >> Transfering sheet set-up
Fri, Mar 28, 2008 at 5:48:15 AM | Transfering sheet set-up
partho
Is there any way we can duplictae a sheet set-up with the views in the sheet in a duplicate file where that particular sheet is not set-up? This is regarding of-loading work to others without central file sharing.
Fri, Mar 28, 2008 at 6:25:32 AM | Transfering sheet set-up
No.
You can set up a file with drafting views on sheets as a project template but I don't believe that will give you what you want.
Fri, Mar 28, 2008 at 6:46:41 AM | Transfering sheet set-up
partho
Thanks. Let me try it out.
Transfering Schedules & Phases (2009)
Wed, Oct 5, 2011 at 10:47:28 AM
Transfering door and window tags to Sheet File
Tue, May 8, 2007 at 2:13:35 AM
Specification Sheet (Notes)
Sat, Dec 20, 2008 at 3:27:33 PM
model transfering to 3d studio
Wed, Aug 15, 2007 at 5:03:40 PM
Printing a set as PDF's
Sun, Sep 24, 2006 at 8:56:03 PM
Page generation time: 0.5590
