Forums >> Revit Building >> Technical Support >> Revit files
Thu, Mar 27, 2008 at 12:14:50 PM | Revit files
JR49
why is it that in revit when you work on a file and change the views there seem to be more files when you save. is there a way to just have one file only.
Thu, Mar 27, 2008 at 12:37:11 PM | Revit files
TJKENNEDY
3 Stars: 2 Votes
What kind of files are being created, and where?
Thu, Mar 27, 2008 at 12:43:23 PM | Revit files
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
I assume you are talking about the backup files that get saved each time.
Ex: Project0801.0001.rvt, Project0801.0002.rvt and so on.
These are the backup files basically they are snap shots of you file from its previous save so you can open them if your current gets corrupt.
An easy way to change the number is when you do a save as; hit the options button in the save as dialog.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Thu, Mar 27, 2008 at 1:23:59 PM | Revit files
JR49
example: if i open a file from my documents and work on it and change the views, when i go back to my documents i see files of the drawing im working on. when i save these files remain. is there a way to prevent this.
i attach an example of what i mean. its a word doc
Thu, Mar 27, 2008 at 1:40:24 PM | Revit files
brettgoodchild
4 Stars: 17 Votes
Again these files are back up files. See my earlier post on how to get rid of these.
The I-Cohouse.0002.rvt, I-Cohouse.003.rvt and I-Cohouse.0004.rvt are just incremental saves there for you so if something happens to your current file you can just continue working from a previous save.
                             ~ Abraham Lincoln
Thu, Mar 27, 2008 at 1:41:31 PM | Revit files
coreed
coreed Avatar
4 Stars: 16 Votes
i think the post from brettgoodchild explains it
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Converting Revit files to AutoCAD files
Wed, Sep 15, 2010 at 2:09:17 PM
HOW TO IMPORT 3DS files and DXF files into REVIT 2011?
Sun, Nov 7, 2010 at 6:21:00 PM
Newbie trying to understand central files vs. import revit files
Tue, May 5, 2009 at 6:55:03 AM
Backup files
Tue, Dec 23, 2008 at 1:48:35 PM
14
View Properties of Linked Revit Files
Mon, Feb 15, 2010 at 9:56:22 PM
Page generation time: 2.3268
