21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Rotating Schedules?
Ive been trying to rotate a revision schedule on my titleblock 90 deg. It appears that it only wants to align it vertically. Any help?
Interesting,
I've never come across anyone wanting to rotate a schedule before...
I'm pretty sure its not possible.
Possible work around would be to rotate everything else in the titleblock and then in projects rotate the views (but that hardly sounds like its worth the work).
We don't use the revision schedule in our office as our office standard is to use letters after tender for new revisions (not currently possible).
I'd probably just do it the old fashion way without using the schedule just drawings lines and text...
HTH.
I had problems setting up our own company sheets with logo etc if I used an existing Revit title block provided.
We set about it from scratch and that worked. Admitedly, for revisions I just left the box blank and we type in text actually on the title sheet as required. Could you put lines in vertically and then just type revisions on sheet as and when required.
5 Posts No Rating |
If there ever is a resolution to this issue it owuld be wonderful so that we may use revision schedules in the titleblock
69 Posts No Rating |
I never had to rotate the schedule, so no solution from me. To automate as much as possible and to reduce changes for mistake, I use a REISION SCHEDULE in the top right hand corner (most of do this) In the drawing titleblock, Where you normally put your 1,2,3...etc, I just have the test: ' SEE REVISION SCHEDULE' With regards to 1,2,3... VS A,B,C .... I believe help is on the way in the new version 2009 Have a nice day Erik
Rotating Symbol geometry without rotating leabel |
Wed, May 6, 2009 at 8:33:58 AM
Rotating mullions |
Thu, Jul 24, 2008 at 4:27:53 PM
Rotating Views On a Sheet [ 1 2 ] |
Tue, Jun 17, 2008 at 12:49:46 AM
18
Rotate Floor Plan without rotating project |
Mon, Nov 4, 2013 at 1:14:56 PM
Rotating Viewports without rotating title |
Wed, Apr 22, 2009 at 10:52:58 PM
