Forums >> Revit Building >> Technical Support >> Controlling how stuff deplays beyond bottom cut plane
Thu, Mar 27, 2008 at 10:45:39 AM | Controlling how stuff deplays beyond bottom cut plane
MYoung
MYoung Avatar
Hi, (Revit 200Shadey
In View Range, I have a typical cut plane at 4' and bottom at 0'.  My view depth is set to the level below so that I can see the below info as a reference.
Is there a way to control how the objects below the cut plane display?  By default they are lighter, but I would like to adjust it if possible.
Thu, Mar 27, 2008 at 12:41:29 PM | Controlling how stuff deplays beyond bottom cut plane
TJKENNEDY
3 Stars: 2 Votes
I am not positive if this is what you are trying to do, but if you go to Settings|Line Styles the top of the list has <beyond> and <hidden> among other things. I am pretty sure those are going to control the objects that are beyond your cut plane.
Thu, Mar 27, 2008 at 12:47:31 PM | Controlling how stuff deplays beyond bottom cut plane
MYoung
MYoung Avatar
Right on, I should've picked up on that but I haven't used Revit in about a year.
 Thanks.
How to control where the cut plane is for families?
Sun, Nov 22, 2009 at 10:19:59 AM
Linked MEP Ductwork not being cut
Wed, Feb 13, 2013 at 9:06:06 AM
Cut plane problems with Families - Revit 2013
Tue, May 21, 2013 at 2:29:27 PM
bottom view in view range is not active, why?
Tue, Apr 24, 2012 at 7:22:57 AM
window above cut plane is visible. why?
Fri, Nov 27, 2009 at 9:25:10 AM
Page generation time: 0.9050
