25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> room tags and room spaces
1 Posts No Rating |
When using Revit to alter existing spaces, it is often the case that room tags are needed in demolition plans and in new work plans and the sapce are often altered due to renovation work (such as sub-dividing an existing space into smaller spaces). How can these spaces be created to display an existing room designation in one view and then be altered to show new spaces and tags in another view. Does it have to do with the way the phasing options are created?
By using phases Revit will allow you to place room tags into an existing plan and into a new plan. The room numbers can be the same and what not. The picture below show existing on the left and new on the right. All you have to do is duplicate you views and set the phase property to show you new or existing and set the phase filter appropriately HTH
Can't create room name in revised room |
Fri, Jun 24, 2016 at 7:21:10 AM
Room Tags on Demo Plans |
Mon, May 9, 2022 at 3:23:12 PM
Room tag not showing in only one room. [ 1 2 ] |
Sat, Sep 27, 2025 at 3:40:00 AM
15
Select room tags; copy rooms to new phase |
Thu, Jun 29, 2006 at 7:19:48 AM
Want to see Room Tags but not Rooms |
Wed, Oct 5, 2016 at 11:37:51 PM
