Forums >> Revit Building >> Technical Support >> DWG and Filled/Masked Region???
Wed, Mar 26, 2008 at 2:17:40 PM | DWG and Filled/Masked Region???
Solopk
I am working on a project where I am designing a penthouse ontop of an existing six story residential project.  I have imported a dwg elevation of the lower six floors into my revit elevation view and I have built the penthouse in 3d.  I want to visually "layer" the dwg in front of the revit model walls...etc.
The lower portion (dwg file) has a parapet wall that in elevation would block the bottom 42" of my new penthouse model.  As I have attempted to get this to work out, the dwg file reads transparent and I can see my model through the parapet wall portion of the imported dwg.  I thought I would just add a filled region or masked region and layer it behind the dwg but in front of my model.  Is this possible?  I cannot find a way to put the region behind the imported dwg file.  Has anyone come across this before?  I am going to have this issue in all four elevations.  Thanks in advance.
Wed, Mar 26, 2008 at 2:43:16 PM | DWG and Filled/Masked Region???
masking regions should not hide any added 2d linework if that is what your cad dwg is.
If this is a 3d cad import, you might try putting a 3d plane in the dwg.
Thu, Jun 7, 2012 at 2:18:16 PM | DWG and Filled/Masked Region???
jdcarling
I am having the same problem did you ever find a fix?
Placing an imported family over a masked region.
Tue, Nov 6, 2007 at 1:02:49 PM
changing Masked Region border lineweight
Mon, Feb 23, 2015 at 5:33:14 PM
Logo / Filled region in Drawing Sheet
Fri, May 7, 2010 at 4:22:30 PM
Filled Region Family Not Displayed in Project Browser
Sun, Nov 9, 2014 at 8:06:37 PM
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Page generation time: 0.5818
