Forums >> Revit Building >> Technical Support >> get the ceiling back after purging
Wed, Mar 16, 2005 at 1:06:34 PM | get the ceiling back after purging
aabrmn
How do you get back the 2' x 4' ACT System ceiling after executing the purge command? I could not find the family in the imperial library folder. Thanks for any suggestion.
Wed, Mar 16, 2005 at 1:29:17 PM | RE: get the ceiling back after purging
aabrmn
I figured this: new file, create ceiling, select ceiling and save to library/save family. any better way to do this? thanks.
Wed, Mar 16, 2005 at 3:34:47 PM | RE: get the ceiling back after purging
aabrmn
actually, the first question is still valid since what I figured did not work very well at the end. what type of family would you suggest on saving out the ceiling (by default it is giving me area tag)? Thanks. Post edited on 2005-03-16 15:38:38
Wed, Mar 16, 2005 at 5:28:58 PM | RE: get the ceiling back after purging
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Start a new project using your template file and open the project you purged the ceiling out of. Then use "transfer project standards" a tick ceilings... This will copy all ceiling settings back to your purged file. HTH.
Thu, Mar 17, 2005 at 10:59:56 AM | RE: get the ceiling back after purging
aabrmn
That worked perfectly. Thank you very much.
Wed, Oct 23, 2013 at 3:34:32 PM | get the ceiling back after purging
ames36075
I tried this with my level head bubble. It did not work. The line shows and if I click on it the boxes show checked but there is no label or bubble for my levels in sections or elevations. Is there anything else I can do to make them show up?
Wed, Oct 23, 2013 at 4:04:19 PM | get the ceiling back after purging
What Revit, what update?  Always post these numbers in your original post.
Fri, Oct 25, 2013 at 10:57:59 AM | get the ceiling back after purging
ames36075
Sorry, Revit 2014 I have no idea about what update. This is our first Revit project and I purged it because there was too much stuff to find what I needed. Somehow I over-rode the level head bubbles and labels. I have tried bringing them in but it won't work. I have to make pdf's for a presentation and all my levels are missing. The line is there but the symbol and the text is gone.
Fri, Oct 25, 2013 at 11:04:00 AM | get the ceiling back after purging
I'm asking about the updates to see if you may have a program problem.  You can look at the dropdown beside the question mark, then the about... and look under the build number.  You should see update 1.  If you don't, then install that update and see if that fixes your problem.  If not, then while in your model, open a new project using a default template.  If it has the level heads, then use transfer project standards to bring them into your project.
Fri, Oct 25, 2013 at 3:16:35 PM | get the ceiling back after purging
ames36075
I have nothing under the build number
When I try to bring them in from a default template i get this box
"The following Types already existing but are different. The Types from the project into which you are pasting will be used.
Levels: Level: 1/4" Head"
When i click close and bring it in there is nothing but a line. the bubble boxes are checked but nothing shows up.
Would it be best to open a new project and just copy everything into it or can you do that in Revit?
Mon, Oct 28, 2013 at 7:41:36 AM | get the ceiling back after purging
#11
Install update 1.
How to load back the Reflected Ceiling Plans into the Project Browser?
Tue, Jun 8, 2004 at 5:41:39 PM
Ceiling objects cut by walls
Fri, Nov 20, 2009 at 12:58:09 AM
Lighting without ceiling
Thu, Sep 10, 2009 at 11:02:50 AM
Room Name w/ manually entered Ceiling Height
Mon, Jan 19, 2009 at 3:50:30 PM
awkward shaped ceiling
Fri, Mar 6, 2009 at 3:36:13 AM
Page generation time: 0.2625
