Forums >> Community >> Newbies >> Column cleanup
Wed, Mar 26, 2008 at 11:35:56 AM | Column cleanup
SWentz
is there a way to make columns placed on a wall surface cleanup or wrap corners?  there are two areas of the model i'm having problems with.  one is an odd existing angle and the other is a 90 degree corner.  images 1-3 show these conditions.
the 4th image is another problem i'm having. as you can see the highlighted colum is adopting the material from the CMU.  i want it to be adopting the material from the brick like all of the rest of the columns.  how do i direct it to recognize the right material?  it is set to material by "catagory" right now.  am i going to have to manually specify a material?
thanks
Thu, Mar 27, 2008 at 10:24:40 AM | Column cleanup
You are trying to use the generic column function work as pilasters.... In most cases, that works ok but your problems are unique.  Why not do these pilasters as independent thin wall sections of the brick material.  Everything will clean up correctly and it will turn the corner.
Wall Floor Intersection Cleanup
Thu, May 4, 2006 at 12:06:45 PM
Custom Wall Cleanup tool
Mon, Jan 18, 2016 at 2:12:14 PM
wall cleanup radius
Thu, Aug 9, 2007 at 4:56:14 PM
DISPLAY COLUMN LABELS
Wed, Sep 8, 2010 at 3:53:41 AM
Column Capitals
Wed, Sep 18, 2019 at 8:39:07 AM
Page generation time: 7.7167
