Forums >> Revit Building >> Technical Support >> Remove/Relocate Doors (or) How to Make a Demolition Door Schedule
Wed, Mar 26, 2008 at 8:24:06 AM | Remove/Relocate Doors (or) How to Make a Demolition Door Schedule
kingkong
I'm using Revit Architecture 2008. My project is an expension/remodel of an existing building.  There are several doors that will be removed and relocated to new locations.  (Other doors will remain or be removed.)  I'll have Demolition and New floor plans.  How can I show these doors properly on the plans and in the door schedule(s) so the field crew knows what to do and the door suppliers know what to bid?
Wed, Mar 26, 2008 at 8:44:58 AM | Remove/Relocate Doors (or) How to Make a Demolition Door Schedule
Gyvven
5 Stars: 2 Votes
I would start by making two door schedules and set one to Demo phase and the other to New. In the comments parameter I'd state "Remove and relocate to ..." on the demo, and "Relocated from ..." on the new one. It would be possible to show both in one schedule if you select show all in the phase parameter, then you could sort by phase, but I'd keep it simple for the contractor to understand by using two scshedules.
Hope this helps.
Door Schedule Problem
Tue, Sep 21, 2010 at 7:26:12 AM
Doors not appearing in door schedule... Help
Thu, May 30, 2013 at 11:58:43 PM
Door Schedule
Thu, Feb 20, 2014 at 7:19:42 AM
Manipulating the door schedule
Wed, Jun 26, 2013 at 10:35:33 PM
11
Door Schedule help.
Thu, Sep 10, 2015 at 1:41:52 PM
Page generation time: 0.7244
